Gas boiler recommendations
boilerworks_2
Member Posts: 2
What are the best options these days for gas (LP) fired boilers? I'm looking for options in the 100-120K BTU (net output) range. It will be used with an indirect for DHW, and conventional radiant heating (baseboard/panel).
I have heard good things about -
WM Ultra, Burnham Revolution II, Buderus GA124
Other than higher efficiency, what are the pros/cons of condensing vs non-condensing? I'm looking for high reliability, low maintenance, top quality (safety).
VITODENS 200
I have 4 running on propane and owners can't belive their bills are as cheap as they are.0
- 86.7K THE MAIN WALL
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
