flow check valves
I need to know if I need a flow check valve in each of four loops (radiant floor) controlled by zone valves off of a single manifold and pump??
Thanks, George
  • Steve_35
    Steve_35 Member Posts: 545
    Not if you have a zone valve in each of the loops. You usually use flow checks when you have a circ on each loop.
