ultra -antifreeze
pete_14
Member Posts: 9
read in one of dan's books that antifreeze can attack aluminum. any problems with Wm ultra boilers and installing antifreeze?will antifreeze destroy heat exchanger?
Ultra
literature names approved antifreeze. I wouldn't deviate from that.0 -
Boiler protection
I have been advised by Weil Mclain Canada the following.
The use of Uninhibited Propylene glycol must be used. Then Fernox Copal inhibitor must be added for the warranty to be covered. There may be other products approved.0 -
Both our cleaner and our treatment are safe to be used
in boilers with aluminum heat exchangers. Also Noble has an aluminum specific glycol.
In fact both of our products are safe with the many metals being used in modern hydronic systems.
Hydro-Solv 9100 cleaner Pro-Tek 922 treatment.
Web site is www.rhomarwater.com
Further questions call 800-543-5975.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
