Radiator valve handles
C Evans
Member Posts: 1
I have a buddy that is looking for replacement handles for some old radiator valves. The handles are made of wood, have a hole in the center for the screw and two "voids" if you will, underneath for the adapter plate to attach to. The plate has two "pins", 180 apart, and a square center that goes on the valve stem. I am hoping not to have to tell him that he has to have a woodworker turn all the handles if he wants them replaced. The system is a gravity fed boiler that had been converted from coal! I can't wait to read more about the things that are not around very much now! Well any way... where can I find replacements?
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
