pipe insulation
David W.
Member Posts: 6
I want to reinsulate my steam mains, where can i get that split fiberglass insulation that i see in boiler rms. Is it availible to the public or only contractors?
Supply
Any Plumbing and heating supply house should carry it. I notice it the other day , high on a shelf in Home Depot....I was suprised.0 -
Supply
I'm sure you can
Plumbers and Heaters hate to insulate pipe David. So go to your local plumbing supply and order what you need. Wiping your arms down with baby power or talc will fill the pores of your skin and help keep the ich away, enjoy. Best Wishes J.Lockard0 -
Home Depot Supply
The last time I checked, both Home Depot and Lowes carried the rigid fiberglass. However, they only carry a few sizes, and they looked to be half an inch or less in thickness. Bleah.
-Michael0 -
Supply House
Like the other posts here, you can get it inexpensively at a plumbing supply house. One of the more recent threads on this forum mentioned that you can buy pre-formed polyisocyanurate tubes as well. Iso I think doesn't fare well after around 240 *F, but that shouldn't be an issue for low-pressure steam. If I knew that, I'd probably have gone for that instead of the fiberglass stuff. Less itch. Higher R.
-Michael0
- 129 Chimneys & Flues
