Great deal for the radiant guys on e-bay see below for info.
John_72
John_72 Member Posts: 7
I am running a Aution on E-Bay for a nice Radiant heating package, Please check it out.
#3873249929
Approx $2000.00 Are Cost to buy New,has a $500.00 Bid.
New in boxs Radiant Heating Controls never use: The following was purchase for a job that never was completed, our lost is your gain.
6- Erie, Low Voltage LCD Heat only battery back up T201 Heating only T-stat 24volt.
3- 3/4" x 1/2" Brass Wells
2-Omron LY2 IEC255 10amp 110Vac 24v Relay Push in type.
3-Watts Heatway #704621 Gauge Tenp 0 - 200f.
1- Tekmar #256 Boiler Control (One Stage) Jul2001 Boiler Control.
2- Tekmar Mixing Control #361
1- Watts Heatway #703125 Vakve Mix Sparco 1"
5- Watts Regulator EDP#0856763 3/4" Brz Swt Flow Chk Valve 2000S M5 For Horizontal Installation.
1- Watts Regulator EDP #0856761 1" 2000 M5 Two-way Flow Check For Angle or Horizontal Install
1- Watts Regulator EDP # 0866760 3/4" 2000 M5 Two Way Flow Check For Angle Or Horizontal Install.
1- Invensys SR-601B 4-6 Circulator Relay Field Selcatable Priorty- No Priority Plus End Switch + Zc/Zr Terminals, Electronic Thermostat Compatible 120 Vac 50/60 Hz
2- Watts Regulator Edp #0386425 1/2" 1156 F Std, Feed Water Pressure Regulator With Strainer and tight seating Check Feature 1/2" Fast fill Reguced Pressure Setting 12lbs.
