Low pressure steam guages
Deb_3
Deb_3 Member Posts: 5
I tried Dwyer Instruments, Weiss Instruments, and Winter. Any other suggestions for a 0-1lb scale guage for steam? All of the above have 0-15lb minimum that can handle the temp of steam, or they do not have a bottom tapping. Thanks in advance. Jake
  • Matt_28
    Matt_28 Member Posts: 34
    Winters
    http://www.winters.ca/pre_lowpressure.html
    they have a 0-5 psi gauge #p305. It also says others available on request. I am just a homeowner that has searched for gauges online before and never saw a 0-1 psi gauge.
    Matt
    Steamhead Member Posts: 17,640
    Winters makes the P305
    0-5 PSI with 1/4" bottom connection. That might be the best you can get.
    Consulting
  • ThermalJake
    ThermalJake Member Posts: 127
    Hey, Steamhead. I looked around Winters site, and I thought it looked like they had one that read down to 0-16 oz/in sq, and it looked like another that read to 0-30 in H2O. When I called, the person who answered the phone said she was not sure if those could handle steam temp. She said that the lowest she new of that could, would be 0-15 lb. I'm going to call again today because it looks like the p305 has various adjustable scales. Maybe I can ask for a special one.
    Thanks for your help. You too Matt the HO.
    Jake
  • Mike J.
    Mike J. Member Posts: 12
    Pressure Gauge
    It is not so much the pressure range as much as the temperature limits of the gauge. You need to use a siphon between the gauge and the steam to lower the temperature.
    Go to Grainger on line and they have 2C639 0/30 iw and a 2C641 0/5 psi and the siphons. These are Ashcroft gauges and the lowest we make in psi is a 0/3 psi but Grainge would have to special order it.
    Mike
  • Steve Garson
    Steve Garson Member Posts: 191
    Also: the Trerice DB00109 Model 760B 2-1/2" gauge for 0-5 PSI. if used with pigtail or syphon is OK with steam.
