expansion tank question
Timco
Member Posts: 3,040
I removed my expansion tank to increase my manifold size and replace / install some swing-check valves. Do I 'purge' or release some pressure from my now empty expansion tank after re-filling the system?
Tim
Tim
charge
Check charge on tank (assuming diagram) with 0 psi on system side.
Air Pressure s/b same as fill valve setting. (typically 12-15psi)
EIN
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
