going to try a....
David Sutton_5
Member Posts: 87
Going to install a W+M ultra 155 2 hydro and indirect. any piping suggestion?? dose this boiler require any specil piping? a picture would be good, ALWAYS steel good ideas from the BEST.... golden rule..:) Thank guys...David
hi David I tried to call you today id like you to install a new cooling system for me this year and id like to have a service contract with you to service all my equipment every year will you serve Wallingford
thanks
So your going to join the Ultra club.....
Welcome!!!!
You'll be glad you did!!!
You HAVE to pipe this boiler P/S..... you must use the 0011 pump for the primary loop and the indirect... make the piping 1-1/4 or larger....good flow is absolutely a must....
I have attached WM's recommended fan coil parameters and the Ultra Interface Kit pdf which shows how to change the factory parameter settings. The fan coil settings are different than what is factory programmed. It will give you a starting point and you can fine tune from there.
I would change #11 to 0 and #20 to 1 for starters. Check #6 you may want tolower that depending on where you live... I seem to remember you being pretty far south, though.....
Have fun!!! It has been a great boiler for me....
Floyd0 -
RoosterBoy
Call me at 1-860-844-0111 or 1-860-818-3036...David0 -
Thank you Floyd
Great!, Thank you very much! i live in southwick mass, my services area is all of north cental Conn. from waterbury to stafford springs and from mass down to glastonbury and areas west . big circle. i'll get a photo when i'm done Floyd, thanks again...David0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
