Cast Iron Redator w/ leak
Timco
Member Posts: 3,040
A welder should be able to use a special cast-iron rod or mig to fill the hole, when the system is empty.
Tim
Tim
Cast iron radiator w/ leak
Is there any procedure (all be it easy?) to fix a leak in one of those old radaitors? It is in the middle of the unit so I tis not a valve problem. Will liquid wrench/ solder work after and if I can find the actural leak? Any and all advice (expecially if it if good) is valued.
Repairing old radiators is mentioned on this site
http://www.heatinghelp.com/newsletter.cfm?Id=20
Around 2/3rds of the way down.
-Michael0
- 129 Chimneys & Flues
- 122 Geothermal
