Buderus 2107 control
Dan_15
Dan_15 Member Posts: 388
The timer cannot be reset. I record/write the "Hours run" on the combustion efficiency tag.Thanks,
  • RoosterBoy
    RoosterBoy Member Posts: 459
    I have been looking at the 2107 manual and I don't see how to reset the burner run time meter should I just remove the jumper turn the unit on then turn it off again and put the jumper back on or is there a better way
    I also have to say I see this unit has been saving money on oil the burner runs for about 40% of the heating call
    my other control ran the burner as soon as the t-stat called till the t-stat was satisfied. not bad at all :-)
    thanks
  • RoosterBoy
    ok thanks joe
