Radiant & Steam
Susan_6
Susan_6 Member Posts: 42
I've done a lot to improve and balance the heat in my house. We still have an open area on the lst floor that is cool. I have two questions:
1. Should we add insulation to the cellar ceiling? This looks like a tough job but I found some thin 1/4" foil that might work.
2. What about radiant floor heat in addition to the two radiators in this area -- does that make sense?
Thanks for your help.
  • John Shea
    John Shea Member Posts: 247
    Do those two radiators heat thoroughly?
    If they're original they should heat the room. Unless of course renovations have been made or radiators were removed.
  • Susan_6
    Yes, they do.
    The radiators are ok. The problem is we altered the room by removing the wall between two rooms and opening up the room a lot. We have new windows, new door and a cover for the downdraft oven vent but it is still cold in that area.
    Below is a field stone foundation cellar, which is getting new windows and a new exterior door this month.
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    there is 1/2 ...
    your problem. You have to seal up the air rushing through the basement. Either by mortar or spray foam insulation. kpc
  • John Shea
    You probably need a heat loss calc...
    to determine the amount of radiation needed for the room. They're based on room dimensions, size and number of windows/doors, insulation, wind conditions, etc.
    If your boiler has the capacity you may be able to add radiator(s).
    Insulating is certainly a good place to start, though.
  • Susan_6
    The thing is,
    I don't want more radiators. I was hoping that installing radiant floor heat would warm up the room without adding bulk.
