How to get air out of Hydronic heating system
ken harrington
Member Posts: 1
How can I get air out of my hydronic heating system.
I want to add more baseboard heat in some rooms,must I drain the whole system or can I just drain the zone it's on
thank you
Ken Harington
thank you
Ken Harington
If
the zone has isolation valves, no problem. In order to solder, you'll have to open the loop to atmospher when soldering. Then, if you're "pumping away," the rest is easy.0
- 129 Chimneys & Flues
