Buderus 2107
Larry_10
Member Posts: 127
hi I am hooking up my 2107 today on my boiler and was wondering if anyone could tel me how to set the DHW
To 122deg and set my space heating aquastat to 185 i am going to run it in manual till i speek with joe monday then we will program it for hydro air
i useed 18-2gauge wire for the out door sensor and i just bought a oem meeter today to check resistance on all the temosters
thanks
thanks
hey rooster boy where are from0 -
im from connecticut0 -
the wiring is a piece of cake on this thing I love it the sensors are dead on when I check them with a ohm meter
so that's good
I just never programmed a 2107 before so I guess I will have to Waite till Monday to turn it on and I will burn wood in the mean time
I just flicked on the breaker for my electric hotwater heater so I will use that for back up for now
till I get help programming this thing. I cant Waite.0 -
There are a few steps to programming. In short detail here they are.
Day Temp - 86, Night temp - 84, In the service level under Circuit 01, Ref temp - 128, OASETBACK changed to SETBACK, Offset to +9. Please call me so we can discuss this. These settings are to insure a homeowner has the water temperature needed. These setting can be adjusted in your own home to lower the temperatures a bit.
Thanks,0 -
thanks Joe I will give you a call in the afternoon i have to take my brother to the hospital in the morning.
my wood stoves are nice but it's allot of work :-) you don't realize how hard your boiler works for you till you start having to burn wood as your primary heat source :-)0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
