Cost of Buderus boiler?
Carrin
Member Posts: 36
How can I determine the cost of a Buderus boiler?
Just ask the company that gave you the bid or get professional quotes done.
PATRIOT HEATING & COOLING, INC.
get a HVAC contractor to come in and quote you a buderus install job?
put it this way a buderus is not much more money then any other boiler at all if any. it's when you get into direct vent is where there is a big difference.
the burner is twice as much and the vent hood are a bit pricy but if I was you have your HVAC contractor install buderus. I have all buderus products and love it.
if your really looking to save money the best advice I can give you is find a contractor that is in the HVAC business and not in the window and drain cleaning business ask to see his work. pictures and call some people that he has done work for and go and see it.
pay to do it right once the first time if you cant afford
to pay what the real pro wants then save your money and wait
don't go to just the cheapest guy and don't go for a guy that tells you. you don't need a permit because you do need a permit. this why here the inspector can check and make sure it's done right.
also come here and ask as much as you can so your an informed consumer
good luck
- 129 Chimneys & Flues
- 122 Geothermal
