gpm
STEVEN MARKS
Member Posts: 154
How many GPM thru old cast iron column radiators?
What is the optimum GPM to get listed btu ratings?
Another \"It Depends\"
But here's an example:
75 sq.ft. EDR cast iron radiator.
180° average temperature (the "standard")
Output @ 180° average = 170 btu/hr * 75 sq.ft. = 12,750 btu/hr.
With "standard" temperature drop across the radiator (delta-t) flow requirement is:
gpm = Btu/hr / (500 * delta-t)
12,750 / (500 * 20)
12,750 / 10,000
1.275 gpm
Is this an existing system being re-worked? If so, be VERY cautious about using 180°. The radiation is generally extremely oversized and a boiler sized properly to the heat loss of the structure will most likely be utterly incapable of heating all of the radiation to 180°!0 -
With lower gpm there are fewer gallons passing through, but each gallon spends more time losing heat in the radiator. The output does drop a bit with lower gpm, because as the water cools in the radiator it loses less heat, but it's a rather small effect. Gravity systems did fine with very low gpm. You can use the lowest gpm that will do the job. That way you'll also get the largest delta-t which is good for a condensing boiler. Multispeed pumps are great for finding out how low you can go.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
