Buderus Question
Dan_15
Dan_15 Member Posts: 388
Hello, I have a quick Buderus question: The little sight window on my G215/4 appears to be partially clouded with black soot or grime of some sort; Im wondering if this is normal or indicative of a combustion issue. Thanks.
  • Dan_15
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    how old is the unit....
    if it's a few years old its normal in any boiler to have SOME soot. The sight glass probably did not get wiped off,not a big deal. When was the last time it was serviced? kpc
  • Dan_15
    Its Brand-New
    The unit was installed in September 2004. It was last serviced about 3 weeks ago by the Buderus expert in the company; the service call was for tweaking the burner (it was inserted too far), adjusting the flue, and generally checking performance to ensure optimal operation. A combustion test was also performed. I just want to make sure it doesnt need another service call because of some combustion issue.
  • Michal_2
    Michal_2 Member Posts: 12
    sight glass
    those sight glasses will darken as the years go on, i have personally instaleld 3 buderuses and i service all of them, and i try to clean the glass. lets think about it, its inside a 600+ degree chamber, with soot and oil, that stuff just bakes onto the glass, I have seen comercial boilers with the same glasses coated with baked on soot. its just one of those things which will keep happenening and eventually you will get tired of cleaning it.
  • Dan_15
    So even the sight glass on a brand-new unit will crud up pretty quickly by its nature; and it has nothing to do with poor combustion.
  • Joe@buderus
    Joe@buderus Member Posts: 165
    Sight glass
    There might have been some residual from the start up/cleaning that can cause the glass to get dirty. I suggest to check it in a couple of days and if appears to get worse contact the installer/technician.
    If there are any questions please contact us at 1-800-283-3787. Thanks,
