1 Baseboard is cold? I have a few ?
Joe.G
Member Posts: 213
Hi, I have all cast iron raditaors except for one base board I can not get it to give off heat it does not even get warm. The ball vavles are open and it is connect right the the main heating line, I am guessing there is a air pocket in it, but i can not seem to get it out, there is no bleeders that I can see. There is a gate vavle on the inlet side I think and there is water there. How can I bleed it? Thanks
Is this a gravity system or circulator??
It has a cirulator on the system.0 -
More questions. Is it a monoflow setup? did it ever heat? Is there a coin vent on the end of the baseboard?
There is not bleeder on teh system, I did install one know becasue some how between trying to get it to work it frozze and I had to replace a the baseboard an da few fittings, now there is a leak where it goes thought eh floor and i can't get to it,. I just shut the ball vavles off that go to it.0
- 129 Chimneys & Flues
