PSI Emergency?
Drew_5
Member Posts: 11
In inspecting my system, I noticed the PSI was at 12 (way too high as per this site) and I notched it down to .5 - 2.5 Without Main Vents installed yet, will the pressure be relieved from the system, or will I have a problem reducing this pressure? Despite the boiler saying max PSI 20, am I in a dangerous situation at 12???
Screw on top of Cut In Valve
I had to replace this screw (missing in the picture) so the Cut-in screw is now attached and able to adjust the setting.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
