Lochinvar Double Duty problems
P. Merolla
Member Posts: 1
Just wondering if anyone else has had problems with leaking heat exchangers in the Double Duty units. I've had 2 start leaking in the last 2 weeks; one was 2 years old, the other was 1 year. The potable water finds its way out thru the weep holes in the inlet / outlet fittings for the heat exchanger, which means the outer wall of the exchanger tubing is leaking somewhere. Just wanted to know if this is a common thing or a freak occurrence before I install any more of these.
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
