Tripple Aqustat
I use to get hot water from my boiler but i change that now. I have a tree family house my boiler will run for 50 minutes before it can hot all radiator. I have tripple Aqustat how do i connect it so that my circulator (which is attach on the returning side) will come on when the boiler comes on, do i have to put on any relay.
  • Harry Sanichra
    Harry Sanichra Member Posts: 33
    Radiator
    On of my radiator no matter how we connect it will take a long time ot heat up. Any suggestion.
  • MR Lab
    MR Lab Member Posts: 3
    Wanna fix your problem?
    I strongly suggest you call in a Pro! Don't mess with a Boiler, don't alter the way it is supposed to work, don't take a chance!
  • deuce
    deuce Member Posts: 3
    aquastat
    set the control to 180/200 diff 10. hook up that circulator to the circulator terminals on the control, so that when that zone calls it will turn on burner and start circ.also make sure you have good pressure in the unit.20psi.also make sure the boiler is fired at maximum.
  • Harry Sanichra
    How do i set the circulator to the control.(this is a tripple Aqustat). The circulator will come on after about 20 minutes i need it to come on when the boiler comes on, is there a special way to do that.
    TThanks!
  • Geno_15
    Geno_15 Member Posts: 158
    DITTO
    no offense but from what you are saying you are in trouble, call in a pro.
  • Harry Sanichra
    Pro
    Before i call in a pro please let me know if that is possiable to do on a tripple aqustat. How do i get a pro those gus from my oil company don't know what there are doing.
    Thanks!
