Paging Tim M! for gas Lighting
Jeff_32
Member Posts: 19
Tim...Hope you can help...Would you read my post on Installing Gas Lighting!? I know someone out there is an expert in this field. There are whole neighborhoods in San Francisco that use gas lighting. I am in NJ and articles have also been written in mags about a few homes in South Orange that still use their original gas lights!
Sorry I did not answer sooner
but I was out of town. I read the post and my first suggestion is to stay away from open flames from gas lights in your home. The potential for increased carbon monoxide is definitely a concern.
I would also check with local fire and building departments for their approval.
If you insist on going ahead a "Google" search of "Gas Lighting Fixtures" will offer you a number of options.
Most gas lighting today is done with a mantle. They are very fragile and also require frequent replacement. They actually last longer when left lit and not shut off and relit.
Is there anything else you want to know?0 -
gas lighting
We still work on them sometimes, we have some old houses (for seattle) that still use outdoor lighting on the drives and walks at their houses. Change mantles periodically and thats about it. They are pretty cool. Mantles don't go out very often. I would stay away from indoor although. Good luck.0 -
Thanks, Tim
for responding.
I am in the process of installing only two SMALL gas light fixtures. I have spoken to three people throughout the US who have RESTORED vintage gas light chadeliers and wall sconces. They use them SPARINGLY and with GREATsuccess.
My question was whether or not you knew what "nozzle", "Burner" or thingamajig I would need at the end of the fixture as it heads into the glass shade. The shade is 4 inches across...and someone told me I need a batswing burner...small tower with a ceramic insert that resembles, (forgive me) a penis with a slit. They work the BEST for natural gas. Just was curious as to where they can be found....
Regards, Jeff0 -
Jeff I cannot really
help you unless I actually see what the light looks like up close. It may also be that it is so old that it cannot be used.0
