FWL & the A dimension?
Jamie_6
Jamie_6 Member Posts: 710
Thank God for patient customers!
We installed a steam boiler around Thanksgiving and we are having a few problems with it. I'll explain some of the stuff we did. It is a two pipe steam system with ½” returns and vented radiators. A hybrid of some sort between two and 1 pipe steam!
• We added two Gordon #2’s to the steam main.
• We added all new Gordon Steam radiator vents.
• We installed a Peerless boiler with a drop header.
• Had to fix one steam leak and one return leak.
• And we had to add a false water line so we had the return wet two where it needed to be.
This was our first FWL job and we did make a few mistakes which we corrected. I.E. - The U seal in the FWL was 6” when we installed it and it needed to be a close nipple. We changed that.
The PROBLEM is this system is HAMMERING & short cycling??????
The last possible thing I can come up with is the A dimension!!!!!!!!
Does the A dimension have to carry over to the FWL? That is at the FWL? Where the equalizer drops down you have to put a tee. At this tee you go up over and down to where the FWL ties in to the wet side of the return. Should that rise coincide with the A DIMENSION?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=289&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
