zone valve I.D. help
m_3
Member Posts: 19
Need help getting info on a zone valve, only numbers I could find on it were RP24-8104. Motorized zone valve, 6 terminal.Sounds like a Taco part number, but I've never seen a Taco zone valve like this. Any help would be app.
Marco
Marco
flair?
Perhaps a Flair Valve? It does not have a manual open lever, nor a spring return. When the motor is jumped out, you can watch the stem keep revolving all the way around. from the open to the closed positions.I realize that flair is not around anmore, but does anybody have any idea where I can get any info? I think that it was never wired correctly in the first place.0 -
Flair Zone Valve
The model number is located at the bottom of the zone valve. Yes it appears that this Co. no longer exists. I have flair model number UB172716 on two seperate zone.
Question: What Honeywell model replaces the above mentioned Flair model, and how different is the hook up.
Thanks for any help.
Handy0 -
Marco how many terminals
does the zone valve have? If it has 6 wiring terminals it can be directly replaced by White Rodgers six wire valve, or Taco or Honeywell. If you get in touch with me I have wiring diagrams to do the replacement. My e-mail address is gastc@cox.net.0 -
It's not a Taco valve part number
Taco, Inc.
Joe Mattiello
Technical Service Technician
joemat@taco-hvac.com
401-942-8000 X 484
www.taco-hvac.comJoe Mattiello
Taco Comfort Solutions0
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
