Spitting radiator vents
BJonesNYC
Member Posts: 2
Hello,
Reading the posting here (and of course Dan's book) have been very helpful to me. I bought an old brownstone with a direct piping connection to my wallet.
Many of my radiators are spitting alot of water. Which means I have wet steam. The third floor radiator air vents and the risers on that floor hiss air loudly. But the one air vent on the main in the basement is always silent.
The pressure is fine and I flush the system weekly. The boiler is new. Spotty asbestos insulation on the steam pipes. Shouldn't I be hearing air occasionally from the main air vent? And how do i get the water out of the system?
I don't know when the last time the wet return below the boiler's waterline was cleaned out.
I'm 40 minutes away
Check the:
Pressure. Should be 0-2 p.s.i.
Insulation. All basement piping MUST be insulated.
Main vent(s). Must be functional and properly located.
Near boiler piping. Must be as per manufacturer's instruction.
I'm in Jersey. (732) 388-1794
Thanks ken,
pressure is 1/2 PSI
vent is near boiler as per manufacturer
Insulation is spotty..I will replace.
Could the wet rturn be clogged..or the auto water feeder be putting too much water into the system0
- 129 Chimneys & Flues
- 122 Geothermal
