Cast Iron Radiators
Sticky
Member Posts: 3
I have about 8 cast iron radiators to get rid of and want to sell them. Anyone have any info? Thanks
Are they
scrolled-topped steam?0 -
You'll have to excuse me but I have no idea what your talking about. What does that mean?0 -
rads
He means:
Did the radiators come off of a steam system? Or a hot water system? If the rads have little metallic things (vents) sticking out of one end of the radiator about half way up the radiator, then they probably came from steam. If the rads have a bleed valve at the top of one end then they came from a hot water system.
The scroll top refers to what the top edge of the radiator looks like. Scroll top looks like, well, scroll work on the top edge.
The next question will be: where are you located?0 -
radiator air vents
Technically speaking, I always use the correct term for the radiator vents: "hissy thingies."0 -
If they look like this...
I can use maybe one of them...and if you are in NJ....I CAN really use one of them!0
