Flow check head loss
Paul_28
Member Posts: 113
Whst is the head loss of a 3/4 B&G Flo Check. The kind used to prevent heat flow.
Contact B&G
I guess my Q: is, are you that close as it may pose a problem? A Swing check has a value of 8.8 feet of pipe steel, with screw connections. Just an Example., I do not have the value of the Flow check that you are asking for.0 -
http://www.bellgossett.com/
B&G has an excellent webpage, snoop around.
hot rod
At 2 gpm
it's 1.5' at 4 gpm it's 3.7' at 6 gpm it's 6.5' and at 8 gpm it's 10'. Source, B&G submittal A-422C . bob0
- 167 Indoor-Air Quality
