snow melting
rick_24
Member Posts: 5
ordered parts for the snowmelt system. system has no sensors installed in slab. looking for snowmelting control that will work , Iwish Iwas on sit when they put system in . I am looking at installing a spst outdoor stat right now notb cost effective any ideas.
Tekmar 362
Mixing control will work - even without the slab sensor. Application brochure is attached,
tekmarcontrols.com for more info0 -
Call me
We can help you out with mixing and slab prottection issues. Controlling the surface temp is another issue. 800-321-4739
Tim D.0 -
switch?
If you need an automatic switch to turn on the snowmelt, look at the Watts LCD-1H Pole Mounted Snowmelting Detector.
www.wattsradiant.com0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
