Wasting energy with recirc.
JohnWood1
Member Posts: 63
http://www.psdmagazine.org/pdf/Sep_Oct_04/14_19.pdf
ASPE article worth the read if you do recirc on hot water systems!
Interesting article, but I'll take issue with the associated cost when both forced and gravity recirculation systems are assumed to have 1 gpm flow with the same delta-t.
Forced systems are likely to have higher flow and gravity system likely to have much less.
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
