Circulator problem
Kal Row
Member Posts: 1,520
some place in the building is not getting heat
wait for your heating professonal
Circulator problem
I am at work and I started to hear a grinding noise in the building. I traced it back to the boiler room and one of the circulators was making the noise. (One of those big red ones) I tried adding oil but it didnt help. I took a closer look and I noticed that the spinning part was a bit out of whack and medal shavings were around it. There is a wall switch for each circ., 6 in all. So I turned it off. The system seemed to be running fine after I shut it down. It probably wont be fixed for a couple of days. Is there anything else I need to do? The system has 2 oil burners linked together and 6 circulators. The other 5 seem to be working fine.
Thanks0 -
Replace the motor mounts on that big red one also.0 -
Spirolink couplings work well.0 -
Circulator repair.
John, you say its one of those big red ones.? Can you get the number off it? If its a series 100, (it sounds like it is from your post) it needs a coupler and new mounts. There are a bunch of aftermarket replacement parts out there but I prefer genuine B&G parts. Again, if its a 100 series, you need coupler B&G 118705+ and Ring motor mount w/screws: B&G 118223.
Robert O'Connor/NJ0 -
if it's a Bell and Gossette 100...
do yourself a favor, and replace it with a taco 007, you can get one the HOME-DEsPOT or sLOWES for $65 cause, a b&g 100, needs 12drops of oil at each end of the motor, and a full ounce of oil, in the center section with the little spring hinged oil fill cap, - each and every year - whereas a taco 007, is silent and dont need a "thang", - not to mention that it draws less than 100W,
the big red pump is a piece of history, i only use the series 100 for a condensate loop off a steam system, and then only in bronze the three-piece: because of the superb starting torque, bronze: so that the boilers iron oxide sludge doesnt stick to it
even b&g makes a water cooled and lubricated NRF-22 that competes with the 007 so unless you have cast-iron pipes and radiation I would change them all out for water cooled/lubricated pumps
It is a 100, I am told it was fixed today. I'm not sure what they replaced it with. I just wanted to make sure nothing was going to blow up by shutting it down.
Thanks for the posts.0 -
Series 100
I agree wet rotor pumps are more versatile, however if your pump reqiurements allow for a flat pump curve IMHO B@G pumps are a workhorse. I doubt well be seeing wet rotor pumps with the same life expectancy of three piece pumps. I agree with one of the previous posts A coupler @ motor mounts should do it.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
