Steam relief valve?
Scott33
Member Posts: 1
I have been losing water in a steam system to the tune of 2-3 gallons per day. Three apartments are in this bugiding all off fo the same boiler/steam header.
I replaced all 8 vent valves and that seemed to help. Then I noticed what looks like a relief valve directly above the boiler blowing steam into the overhead space. It sits vertically on top af a 6-8 inch stub connected directly to the main steam header. It's above a covering and with the furncae running I never really heard the noise from it before.
Is this a safety relief valve or a vent for the main header??? It seems like a vent should be located at teh end fo the main and not right at the boilder so my guess is that it's a relief valve that's stuck open...or the system pressure is too high and it stays open to protect the system.
Any help is appreciated.
could be either
send us a picture0 -
relief valves are usually on the boiler itself0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
