Oil Fired Unit Heater selection
Einsiedler_2
Member Posts: 93
I am having little luck in helping a customer locate some Unit Heaters. I am hoping some wallies may be able to steer me in the right direction (or advise if NOT available)
Reguirements:
9-Units Required.
Oil Fired - Must be able to burn Diesel Oil
350 MBH +
50 ft throw from 30ft mount height
PowerVented
any ideas?
I luie of unit heaters I may offer a 3000MBH waste oil Furnace and have him duct it to areas.
thanks in advance,
Einsiedler
Reguirements:
9-Units Required.
350 MBH +
PowerVented
any ideas?
thanks in advance,
Einsiedler
Thermocycler
If this is an open wharehouse area you may want to look into one of these units. Very well made and helps reduce stratification. www.thermocycler.com
Also will greatly reduce chimney/venting and oil supply piping costs.0 -
I like these too
and have used a bunch over the years. Make sure you spec out the burner YOU want! They pretty much build to order, so.........
http://www.powrmatic.com/usa/Product_UnitHeaters.php
Also, single biggest thing I see wrong on these jobs is the supply system, do a little reading here first, FACT!
http://suntecpumps.com/Technical Literature.htm0
- 129 Chimneys & Flues
