check-trol by B&G
jim P._2
Member Posts: 28
Has anyone used the B & G Check-trol? It looks like a great product. The reason I am asking is the 200 F max.working temp. the litereture states. I have my boiler aquastat at 180 F and when it gets real cold I turn it up to 190 F ( once this year). Am I cutting it too close if I use this product on my system. A homeowner. Thanks. JIM
check-trol
Jim I to am a HO and have 4 of these on my system, been in operation for the past 2 years, no problems to date with the temperatures you mention. Hopefully we will hear from some of the professionals.0 -
i think they are trying to scare us from...
soldering it without a wet rag, cause most system are running into those temps - if they really meant 200f wet, the valve would be usless
the grundfos and taco ifc pumps come with a spring checks made out of the same nitrile stuff and they are rated above the 220 upper limit of your typical aquastat0 -
Chek-trol Isolation Flow Control Flange
Kal, the 3/4 " model 101231 comes in 3/4" NPT. No soldering involved. It still says 200 F Max. operating temp. Jim0 -
Ernie, Just to make sure these are the Isolation Flanges by B&G with the built in check that I was talking about. What temperatures are you running by them? Are yours installed vertical or horizontal? B&G Literature does not say anything about orientation. Thanks Jim. Back to the super bowl game.0 -
Jim
Sorry it was B&G Hydrotrol Flow Control, they have a Max operating temperature of 250*F, according to their Web Site.0 -
I used the flanges on my new radiant system. My boiler loop temp. only gets to 190 deg max. I have them in vert. and horz. positions. The system is in my own house and has been running since the beginning of December. The flanges seem to work very well. I did not have a problem when I soldered them. The brass valve makes up the actual face of the flange, and the ears of the flange can spin 360 so you can put the bolts and nuts in the most convenient spot. I will use them again. Once these catch on it will be so easy to replace a pump.0 -
jim may be right
i would appear from this web site
http://www.dynalabcorp.com/technical_info_acetal.asp
that it's the acetal palstic check itself, not the nitrile that is the limiting factor0 -
Acetal max working temp
is 180 F according to the link you posted Kal. I would still like to hear from a B$G tech rep concerning this matter. Clearing this up will determine whether I use this product(at180-190 F). Thanks Jim0 -
Ernie How do you like the Hydro-trols? My second option is to use the B&G isolation valve without the check (rated at 250F) with the hydro-trol (rated at 250 F). The B&G check-trol isolation valve is cutting it a little too close with the 200 F max. design temp.0 -
check-trol iso valves
Ed do you have the isolation valves with or without the built in check valve? Do you have any concerns about the max working temp. Jim0 -
Hydro-trol
Jim they have not given me one bit of trouble and would use them again if the opportunity arises. You can see three of them neatly tucked between the circ's the fourth is hidden.0 -
Nice. Are they installed on your returns?0 -
No Jim, they are actually on the supply, the circ is comming down from a primary loop and makes a U turn and up and out to their respective zones. Works great.0 -
cant seem to raise the b&g rep...
everyone is at the ASHREE show in orlando
i left this message on their site
please go to heatinghelp.com and respond to this thread about a "checktrol" issue -lets see if they bite
http://forums.invision.net/Index.cfm?CFApp=2&Message_ID=154660
anyway: attached is the pdf from the taco 007ifc - same material names - but rated for 240 - so the plot thickens...0 -
here is the gundfos...
again same materials and 230f
but they give you temps tables based on ambient air
also they give you a nice min inlet pressure per temp table, they dont want you cavitating their pumps to death with hot water flashing into steam in the impelors inlet!!!0 -
dont get it, if useing checktrol's - why the heat trap loops?
Kal
Was not meant to be heat loop traps as they do not go down far enough before they turn up and out to the zones. If I open up the checks they will bleed hot water into the zones.0 -
They all (taco,grundfos, B&G checktrol) have
> again same materials and 230f but they give you
> also they
They (Taco,Grundfos,B&G checktrol) all have
ACETAL as the limiting factor. According to the link for plastics the max. temp. is 180F for this plastic. How is it that these products are rated higher than this limiting factor. Do they go bad after X amount of time? There is a world of diference between 180 F and 200 F and/or 230F. I am just a homeowner but something is not right here. Jim0 -
The manufacturer of the check valve that is used in the Check-Trol, rates the check valve at a maximum temperature of 200 degree F at 150 PSI. We are comfortable using this device to the maximum temperature of 200 degree F.
best regards,
Dan Schaffer
Bell & Gossett
can the check be reversed in the body...
also is the ball valve full port?
i use lots of ballvalves, spring checks, and flanges, and usually in succession - and usually with a drain ball valve - which would be a nice option
Should you decide so add a purge port option - please cast it with multiple threaded bosses with plugs in the unused ones, (see pic below). With the raven-sales and webstone ones, i always manage to end up with the purge port facing upward
Personally, I would cast a square block next to the ballvalve low enough so that the ballvalve handle can clear over it to the open position, and drill two ports, upward and downward, and plug one, and screw a long necked ballvalve purge to the other, this also has the advantage of not having the purge ports inline with the piping plane where its difficult to hook up a hose between the pipes0 -
Ernie - did they come with a blank flange plate also??
Flange Plates
Kal no blank flange plates on the Hydro-Trols checks.0 -
any plans for bolt insulators...
i have just about had it with large size dielectric unions - the plastic parts, crack and disintegrate from temperature swings, and then the union walks itself apart
how much could fiber bolt sleeves and washers cost already? I do it now with heat shrink tubing and fiber washers but it would be nice if someone sold a kit with,
2 bolts same torque, and same 5/8 head but thinner, 11/16 nuts but with matching smaller inside threads, 4 half flanged sleeves and 4 washers, 2 lock washers
see picture also whatever happend to my request for movable, integral ball purge in front of the pipe plane also in pic0
