Can a probe type Steam low water cutoff be used
Mad Dog
Member Posts: 2,595
If not, what is the difference. I know, they are more expensive, but is that all. I mean, they both have to perform the same function, right? Mad Dog
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=210&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
why not. they both look for the same thing. continuity. fluid, water. probes should be able to handle the temps?. but if there ever was a claim for a failed boiler, and someone noticed hot water lwco on a steam boiler, they might ask why. john0 -
why not? they both look for the same thing. continuity, right? water, fluid, should be able to handle temps. only problem if its marked, and its on the other,and there is a failure, wooops. john0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
