l.w.c.o.
Jack_19
Member Posts: 16
I would like the recomending of a l.w.c.o. that would shut off the 24 volt gas circut in case off a low water incident but not be so sensitive to a voitage spike which mine is, so far this heating season the reset has tripped twice do to spikes,and one that will also shut off the 120 voit cir. pump in case off a low water incident. Thanks. C.D.
l.w.c.o.
I would like the recomending of a l.w.c.o. that would shut off the 24 volt gas circut in case off a low water incident but not be so sensitive to a voitage spike which mine is, so far this heating season the reset has tripped twice do to spikes,and one that will also shut off the 120 voit cir. pump in case off a low water incident. Thanks. C.D.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
