blower motor, intermittent starting problem
Flangehead
Member Posts: 20
Hey guys went on a call, forced air furnace, blower motor marathon motor, no capacitor, intermittently, motor tries to start and hums, give the pulley a little push and she takes off. Motor replace 1.5 yrs ago, oiled bearings, belt alighment and tension looks good, motor and fan spin freely by hand, as I said the motor does not always have a problem starting up, just occasionly, I'm thinking possible dead spot in the motor windings?
chk capacator
Chk capacator with a cap teaser supco has a good inexpensive one or just replace the cap with one with the same rating s graingers usually carries most common caps peace clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
no cap on this one big guy0 -
ohm
ohm the motor out looking for flat spot's. I have a feeling you will find one. If unsure how, take the power lead's off, attach a good meter and turn the motor very slowly looking for spike's or large drops in the ohm reading....:)0 -
Thanks that's the answer I was looking for0 -
motor starting
Could also be a dirty start switch sticking periodically. Not very repairable but gets you in the right direction.0 -
Motor
I agree with dead spot. Change out to PSC motor instead of Shaded pole motor. Also watch your HP. your motor is probably 1/5 hp motor. go with 1/3 or so.0 -
Check voltage
Check the voltage to the motor on start, a bad relay contact or fan switch can drop 20 volts or so. Also,see what the rated amps are, clip the motor to see if the current draw is normal. The start switch is a good tip, especially if over oiled.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
