One-pipe Coffee Maker
John Shea
Member Posts: 247
Recently, with temps in the teens and below (here in MI), I have noticed a strange sound in the main of my one-pipe steam system. It almost sounds like a mild Coffee maker.
Is it that there's an abnormal amount of steam and condensate flowing? There's no hammering, just kind of a flowing sound.
Thanks!
Thanks!
bump
to the top0 -
Is the main
insulated? How about the runouts to the radiators?
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
The mains are thoroughly insulated.
A little has been replaced w/fiberglass, but most of it is air-cel(I believe). The horizontal runouts are insulated. What's in the wall, I do not know. I have a feeling they are not.
It seems to only happen when the tsat calls for heat frequently (real cold outside).0 -
Wet steam is the next suspect
This can be caused by dirty boiler water (which may or may not show up in the sight glass) or improper piping around the boiler. If the level in the glass zooms up and down, you have a dirty water problem.
Consulting0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
