got a quick ?
jeff_51
jeff_51 Member Posts: 545
pulled out a 672,000 btu steam boiler yesterday and today. Emergency job, it had failed big time. It is a single pipe with condensate return pump. Haven,t been able to get ahold of any suppliers about availability of a boiler that size. Not hopefull, will prolly have to go with two smaller ones. I know you shouldn,t run a single boiler feed pump to two boilers and am assuming you shouldn't run a single condensate return pump back to both boilers for the same reason. I am right on this?
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,611
    Yes,
    that's right. The pump doesn't know which boiler needs water, and the boilers will not have equal pressures inside of them.
    Retired and loving it.
  • jeff_51
    preciate the quick answer
