Pex Tubing?
Larry_10
Member Posts: 127
what would be a good pex tubing to use for baseboard heating I would need it to work at more then 180deg if need
sometimes at 190F I would need 3/4 inch
thanks
thanks
We use a lot of
Viega FoSta pex (fosta meaning form stable). It's a PAP type product with a sterling track record. The nice part of this, and most other PAP pipe is the expansion ratio is about the same as copper tube. This eliminates a lot of issues with noise associated with regular pex. The fitting system that Viega has is nice because it works with regular pex as well as the PAP. Try it you'll like it.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
