2\" TRV's?
MikeAR
MikeAR Member Posts: 15
Does anyone know a distributor that has large diameter TRV's? The pipes running into my rads are either 1 1/2 or 2". I'd like to add TRV's in the future, but all I have found are up to 1".
Mike A
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Largest I've seen are 1¼" (Oventrop, Danfoss and likely others).
    The good thing is that those rads most likely don't need more flow than can be provided by even a ¾" valve.
    The bad thing is that you'll need some piping modifications to use the TRVs. Eccentric reducing couplings would come in VERY handy if the pipes are coming up through the floor and have little or no "play" to compensate for the increased center-to-center distance when you reduce the size of the riser. No need to reduce the return side connection at least.
  • tim smith
    tim smith Member Posts: 2,835
    Honeywell/sparco
    Just used the V8000 series high capacity valves. 1', 1-1/4" and 1-1/2" sizes. Work great, good CV ratings also. Good luck, Tim
  • Uni R
    Uni R Member Posts: 663
    Pipe sizes
    That's really large... Not sure if you know but boiler piping is based on the internal diameter of the pipe.
  • jeff_51
    jeff_51 Member Posts: 545
    do you perchance have a one pipe system???
