sludge in oil tank
zeke
Member Posts: 223
Can anyone recommend a sludge cleaner for an indoor 275 tank 14 years old. It is a single pipe syatem.
Thank you.
Thank you.
curious
Are you having issue's with your system? Do you have any sign's of moisture on the bottom of the tank? Is the tank angled toward's the filter? You may find you are better off to replace the tank and line to the unit. Just my .02 cents..0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
