Do heat calcs really work?
Leo G_99
Member Posts: 223
we did a 12,000 sq.ft. home, and the heat calcs called for 150K heatloss design temps. I went along with it with a lot of trepidition. But we have just gone through a 2 1/2 week priod where the temps actually dipped lower then design day a couple of nights. I was expecting to get a call from these customers, but nary a ringy-dingy!
Wow that feels good!!!!
Leo G
Leo G
As a rudimentary guide:) how now brown cow0 -
Therefore...
Your heatloss calcs are overstated, as we suspect most are. Had it been more accurate, you well may have heard about it.0 -
ahhhh,
But Uni, you forget, the calcs are for the whole house. and the chances of every zone calling for heat at thee samr time is remote.
Leo G0 -
A heat loss calc
however accurate or inaccurate is just a snapshot, or point in time. The house may never be EXACTLY at that number as temperature, R-values, construction and the biggie INFILTRATION are impossibe to calculate exactly.
A closer calc would be to perform the load calc after the home is built! A blower door could pin down the infiltration much closer this way.
I suspect all programs have a bit of a fudge factor, and will usually cover you below design, to a point
Radiantly heated homes also benefit from a flywheel effect when the MRT is considered and all the objects in the room become emitters to carry through some below design periods.
Forced air isn't as forgiving in this aspect.
hot rod
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
