Expansion tank
John_70
Member Posts: 5
I noticed that the expansion tank on my boiler rusted out and was leaking pretty good this afternoon. I purchased and installed a new tank and I thought all went well. They are both listed at 12 psi. Now the relief valve is leaking. Anyone have any ideas?
is it a diaphram tank or
a compression air tank?gwgillplumbingandheating.com
It is a Watts ET-30
Pre-charge Pressure 12PSI
Working Pressure 60PSI
Hydrostatic Test Pressure 75PSI
Operating Temp 240F0 -
did you check the air charge
before installation? what about the fill valve on the system, is it bleeding thru?gwgillplumbingandheating.com
I used a tire pessure gage on the new tank, it was 12 PSI0 -
What's the pressure
at the boiler gauge?
hot rod
it is between 15 and 220 -
sounds like a bad relief
there isn't a valve between the expansion tank and boiler is there? If there is, is it open????0 -
I was thinking that it may be a bad relief valve. I guess that the old expansion tank was weakest link and that the new tank is putting pressure on the relief valve. Does that make sense?
It is dripping about a quart an hour.
Thanks everyone for your help and suggestions.
John0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
