collis radiator valve
Mr. Blonde
Member Posts: 38
My steam experience is not the best so bear with me.I looked at a system the other day that had a collis rad. valve on it. Rather than 1 tapping coming in the bottum it has 2 3/4" that come in the side, one that goes to supply header and 1 that goes to what appears to be a condensate return header. The radiator is a 1 pipe with an air vent. Ive never seen a valve like this, can anyone help me with information about it and if they are still available or what you can do for a replacement.
thanks in advance
thanks in advance
This should help..very old stuff..
I'm working on a book with steve pajek that will have this type of info in it..Dan knows of the project and will eventually sell the item(s) here.. but in the mean time i hope this info helps..would hate to see these babies removed tho..these museum pieces should be repaired if possible..if you have to remove it, keep it as a trophy..if you remove two, i would love one..these are in word document format, and should answer your questions..glad to help..gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
