bronze body pump required?
IZZY
Member Posts: 59
I have to replace a circulator on a hot water baseboard loop off the bottom of a steam boiler. The old circulator is a bronze body. Can I replace it with an iron body pump?
izzy
yes. People use the bronze one due to the corrosive nature of the condensate and the rust and stuff that accumulates in the system. It is suppose to last longer but that too is open to interpretation. Many years ago I only installed the bronze one, now its usually the cast one only because I've seen the good ones break just as often and quite frankly you can buy 4 pumps for what the bronze one costs. You choose, its only money!..Robert O'Connor/NJ0 -
thanks
thanks for the info0 -
Unless I'm mistaken, the only time you are required to use a bronze bearing assembly/volute is when you have a pump in domestic hot water-but even then, you can use a standard motor to run it.0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
