Best way to clear a clogged wet return?
John Shea
John Shea Member Posts: 247
Anyone ever try it WITHOUT draining the boiler/piping?
Thanks in advance for your input.
  • We use a mild liquid cleaner
    but you definitely want to drain what the cleaner dredges up and brings back to the boiler . That primordial ooze won't disappear on it's own . Is there a situation on this job that makes draining the boiler a hassle , John ?
  • John Shea
    Yes.
    After a previous run in with a different return, I had a real hard time getting the water clean. The owner should own stock in SQUICK, Rust Raider & Vinegar.
    I thought if I could free it up mechanically (small snake) I could possibly drain the sludge off the bottom of the boiler (after it settles). Sounds like that's not such a good idea.
    It's about 10F here in Detroit, and I don't want to fight to get new feed water to produce dry steam. (this Peerless boiler is very fussy about cleanliness and pH levels)
    Maybe I'm trying to cut a corner that should not be cut.
    Thanks Ron Jr.
  • Dan C.
    Dan C. Member Posts: 248
    I used my super vee
    on the last one and it worked pissah.
  • Ahh , coincidences
    We had a run in with a Peerless steamer today . We replaced this one in November , and there was alot of banging and spitting vents . We raised one dry return , added a main vent to another and cleaned the **** out of the system . The old boiler was piped atrocious to begin with , and with limited room we did the best we could .
    To clean this one we dumped out all the water in the boiler , added some squick , refilled and let it steam for a while . We kept the valve closed on the return and let the dirty condensate drain into a bucket to flush all the crap . After about 30 gallons we shut that down and skimmed the boiler - another 20 gallons or so . Then we drained the boiler and refilled . Didn't hear a ping through the whole process and the water was crystal clear when we left . Hope it stays that way for a while .
  • John Shea
    Nice work, Ron
    I hope you buried that boiler you replaced. It appears older than prostitution.
    There's probably no way around draining the system. I've got a good 75' of that wet return that I think is the problem.
    Just curious, Is that a return 'manifold' & drip on the left? Pretty cool. Wish I were a fitter.
    Thanks again.
  • Yes , we had to build
    our own mini-main to reconnect 3 individual rad pipes . There were another 2 - 2 inch mains we had to reconnect also - making it 5 pipes that had to be rejoined . I'm not ashamed to say this job really sucked . This was in a very tiny and short basement with stairs you had to duck under to get down . Thanks alot John and good luck with the returns on your headache .
