My first snowmelt
Wayco Wayne_2
Member Posts: 2,479
yesterday. I've been waiting impatiently since last Spring My wife and I put in a sidewalk and I snuck some insultarp and pex into it before the pour. (BTW, She thinks I'm nuts. Perhaps:P) My idea was to run the snowmelt just to prevent ice spots since I've got a snow blower for the preponderance of the snow. Unfortunately my results were mixed. Parts of the sidewalk got up to 49 degrees when checked with an infared thrmometer, but other spots several inches away stayed below 30 and the ice did not melt. I have no experience to draw from. Are the cold spots due to different depths of the tubing. Did I not run the system long enough? Would it have evened out in time. I thought there would be more conduction in the concrete to give a more homogeneous temperature. Should I have left the snow on top to give an inulating cover that would have spread the heat out? I scraped the snow off with the snowblower first. Did I run my water too hot? Any feedback from more experienced wallies is appreciated. WW
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Snowmelt
Snowmelt tubing should be run in a counterflow method. Can you tell me how many loops you have, what spacing they're on, and loop lengths? Are these on valved manifolds that need to be balanced?
Regards,
PR0 -
Yeah Paul
I got 2- 125 foot loops of 5/8 Pex at 10 inch spacing. The water temp should be 126 but I went up to 135.
how long
how long did you run the system before taking the readings?
brent0 -
A couple hours
Funny it was clear this morning. I probably didn't wait long enough. We are going to have snow again this Sat. I'll play with it again then. WW
A couple hours
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
