pH adjustments in Peerless Boiler
gerry gill
Member Posts: 3,078
just out of curiosity..i use swimming pool chemicals..
gwgillplumbingandheating.com
Are there any risks with using Vinegar...
to lower the pH of the boiler water in a Peerless boiler. I have been told that adding too much could potentially eat seals or gaskets?
Would this be something specific to Peerless or have I been given false information?
Peerless, of course, doesn't recommend it. They refer me to a chemical treatment co. which at the present time I cannot afford.
Thanks in advance for your help.
Boiler's rated for 1.5 million btus output. Not sure how much water it holds, but I added one cup and it dropped to 9.54.
A month or so ago I added two cups, because the pH was over 11.0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
