Bladder tank
JimGPE_3
Member Posts: 240
Hot water system has a bladder type expansion tank. Water connection faces up, air coushion and pressurization connection are on the bottom. If you depress the schraeder valve at the air connection, water comes out.
This means the bladder is ruptured and the tank is toast, right? Is there any way I can get water out the air connection WITHOUT the bladder being ruptured?
Thanks.
Thanks.
water in air valve
you need a new pressure tank0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
