Safety Switch
Doug_26
Doug_26 Member Posts: 2
Hi ---
I have a Beckett boiler (don't know the model number) with a Honeywell 8184G protectorelay controller. Just in the last day, the safety switch has started popping up. I will go down to the celler and reset it and the burner will fire right away. The switch seems to invariably pop open again, though. Sometimes it is fairly quick - it'll pop up in just a few minutes but other times the boiler will run for a few hours and then it pops up.
I'm not looking to do any repairs myself, but i am looking for possible reasons why this is happening. Do I need to get my oil tank filled up? Is there a vacuum in the oil line? And why does the switch come up in the first place - is it sensing that the burner is not firing?
The boiler just underwent and inspection/cleanout/maintainance procedure just about two months ago and has been running great up to now.
I appreciate any comments!
Doug
  • ed wallace
    ed wallace Member Posts: 1,612
    safety switch
    somethings not right call for help before it locks out and you have a freeze up
  • Doug_26
    Thanks for the reply.
    But do have any information that you can give about the switch. I really don't like to have work done on anything of mine without at least a general knowlege of how it works or why it is there in the first place.
    --- Doug
  • ed wallace
    saftety switch
    its a control which shuts the burner down on a loss of flame it could be a bad conttrol or a bad cad cell eye you are not competant to fix it call for help
  • lchmb
    lchmb Member Posts: 2,997
    lot's of possible answer's
    It could be the cad cell is not sensing. It could be the unit is overaired. It could be the primary control itself is bad. Best to have a pro come in and run a complete diagnostic before it get's worse...
  • Kinda harsh there Eddie
    No need to reiterate his lack of competancy in handling the repair himself . Doug said in his original post he knows professional help is needed .
    Doug , it really could be a number of things happening . No fuel in the tank , clogged oil lines , leaky oil lines , clogged filter-strainer-nozzle , bad cad cell or eye . Just to name a few . This type of problem is hard to diagnose over the net . Do you have a service contract with the last company that came out ?
  • Leo
    Leo Member Posts: 772
    This is the type of calls I mainly do and it can sometimes be a challenge being right there. Call someone in and let us know what was found.
    Good Luck,
    Leo
  • KHinton
    KHinton Member Posts: 1
    This is your Primary control, not only can a number of things cause this to lock out, all of which are safty issues, but the more you reset the control, the closer the control is to failing itself and you will not only have to fix the original problem, but you will find yourself replacing the primary control as well.
